Maintain proportions
12008.1
I rarely use maintain proportions, and inevitably forget to uncheck it when I first change the size on something. I could not find a likely setting in the init file. Is there a way to make the default unchecked?
12008.2 In reply to 12008.1
Hi sos, there is a startup script in the below link which you can place into the appdata startup folder. You should then get "Maintain proportions" off for its initial display.
http://moi3d.com/forum/index.php?webtag=MOI&msg=10114.636
