SCRIPT IN MOI3D
All  1-3  4-9
12005.4 In reply to 12005.3
Hi JOCONDOR, there isn't any official API documentation but there are some things collected here:
http://moi3d.com/wiki/scripting
AI tools seem to have trouble making MOI scripts, either because of lack of documentation or not enough examples for them to train on.
They often seem to generate a bunch of wrong non-working code. I would recommend to not use one for trying to write MOI scripts.
12005.5 In reply to 12005.4
I'm getting help from the AI, and I'm having trouble. I've made some small improvements with the script. I'm attaching the files here.
12005.6 In reply to 12005.5
Hi JOCONDOR,
Could you describe the trouble?
12005.7 In reply to 12005.6
Hi Michael, the problem is this:
When I select a line, a menu should open that allows me to select the various HeA profiles, etc. Then, based on the one I choose, a solid with the chosen profile will be created from the line. Unfortunately, it doesn't work. I'm not a computer engineer, but a construction engineer. I don't have any programming language skills.
12005.8 In reply to 12005.7
Hi JOCONDOR, I'm sorry but some programming language skills are a necessary prerequisite to be able to make MOI scripts.
AI tools do not seem to do a very good job making MOI scripts. I'm not exactly sure why that is, possibly there is not enough data for them to train on.
You may need to find a partner who does have some programming background to work on your project.
Or perhaps try the node editor, it is a type of simplified graphical programming language:
https://moi3d.com/wiki/Nodeeditor
12005.9 In reply to 12005.8
Thanks for the advice. I'll try to download the plugin.
Show messages: All  1-3  4-9
