Moi3d and 3d scanning
All  1-3  4-7
12004.4 In reply to 12004.1
Hi Matadem, From what we gather, scanners still output mesh data first (OBJ/STL etc), then 'reverse engineering'
software tries to rebuild surfaces/NURBS from that afterward. As Michaels post indicates.
QuickSurface looked interesting because it seemed more affordable than the Geomagic ecosystem:
QuickSurface
There’s also a Personal version:
QuickSurface Personal
The newer Creality entry level scanners also seemed surprisingly decent for the money:
CrealityScan Wiki
From the little bit we researched, the rough scanner landscape seemed to go something like this (cheap → expensive):
- Creality
- Revopoint
- 3DMakerPro
- Einstar (Shining3D)
- Shining3D
- Matter and Form
- Peel 3D
- Artec
- Creaform
- Faro
- Hexagon
- Leica
Research the names above here
Might also be worth checking out some of the Shining3D stuff as they have both entry level and also
seem to push the “metrology-grade” angle quite hard on some models.
I am not suggesting any of the hardware listed here is good.
Video:
metrology-grade = expensive machines that measure things so accurately they can probably detect your modelling mistakes before you do
Nicely presented 'review' - not sure if unbiased or not at this moment:
https://all3dp.com/1/best-3d-scanner-diy-handheld-app-software/
EDITED: 21 May by LIGHTWAVE
12004.5 In reply to 12004.1
I got an old Nextengine laser unit and some geomagic software tied directly to that model a while back and tested it out for a week or two
I only paid a few hundred dollars for the lot but the original full setup bought by universities etc would have been around $30,000, most of it for the geomagic software.
Well I really struggled to make it work and abandoned my efforts after a couple of weeks because I just couldn't make it work for me, and most jobs can be solved with a good set of calipers.
Plus some of the file useage was massive and even my six core computer was taking ages with GM
Anyway. I came back to the STL files with a bit of MOI under my belt and looked at improving scans via MOI and I reckon this is the way to go for us poor people and it's far simpler.
You can use MOI to build the scan into sensible parts, the first part you have to do is the "Origin" part and then you build the other sections around that part to achieve proper squareness in three dimensions
I've done hardly anything on this stuff, it's been a whole new area of learning but the geomagic part for me was abandoned pretty quickly
So my recommendation for a cheapie 3D setup is get a scanner that does good STL files, and use MOI to orientate/Build your result into a full drawing
for stl/stp stuff I used Alibre
https://www.alibre.com/forum/index.php?threads/new-add-on-for-conversion-of-stl-to-stp-and-open-in-alibre-complete-c-rewrite.26312/
my 2cents
EDITED: 30 May by ADO1
Size: 712.7 KB, Downloaded: 18 times, Dimensions: 1920x1080px
Size: 631.7 KB, Downloaded: 13 times, Dimensions: 1920x1080px
Size: 645.5 KB, Downloaded: 18 times, Dimensions: 1920x1080px
12004.6 In reply to 12004.5
Hi ado, the kind of odd looking lumpy shaping comes from using the MOI SubD converter on a mesh that has not been set up for sub-d smoothing.
Here's some examples of how the control mesh should be formed for sub-d smoothing to make a good quality result:
https://www.youtube.com/watch?v=ckOTl2GcS-E
12004.7 In reply to 12004.6
I have more detailed stuff via a 50MB Alibre Stp
Which converts to a 75MB MOI stp (about 10 mins)
and a 132MB 3dm file (a few minutes)
It's the processing time for these things when you're just experimenting, it starts to get silly pretty quickly
If you're getting money for a job no doubt it's worth more hassle
Size: 655.6 KB, Downloaded: 2 times, Dimensions: 1920x1080px
Show messages: All  1-3  4-7
