Moi3d and 3d scanning
 1-18  19-21
12004.19 In reply to 12004.18
Hey, I downloaded the STL file and, using Blender with an add-on called “QRemeshify”, I converted it into a quad topology mesh.
Then I exported the model as OBJ and imported it into Moi3D using the SubD command.
I’m attaching the OBJ file below, so you have a model in Moi3D to work on that’s lighter than an STL file.
You can also find QRemeshify on GitHub, but maybe from this link (https://ksami.gumroad.com/l/QRemeshify) you get a version that works with the libraries as well.
However, if you’re dealing with this kind of file, you might want to consider Quad Remesher, which I already mentioned in my previous comment, because it produces a much better remesh.
From any of your devasted images above you can have that!
Rodin or Tripo
Meshy
Krea 2
Here i take only one image (you can take 2 images in Krea)
Finally only Krea gives free models :) (from that i speedy test )
But heavy one and triangulated
So must use for example some quad decimater
EDITED: 1 Jun 12:32 by PILOU
12004.21 In reply to 12004.20
This is impressive, really.
i can't wait to see the finished model
Show messages:  1-18  19-21
