Moi3d and 3d scanning
All  1-15  16-19
12004.16
@pafurijaz
end result looks good
12004.17 In reply to 12004.15
I can supply the original stl the nextengine produced so folk can play with it
knock yourselves out
Whoever can do the smallest good looking nurbs file, for MOI editing/creating a sexy final object, is the goal.
and that means that MOI users can do 3d scanner work on the cheap
EDITED: 1 Jun 8:56 by ADO1
12004.18 In reply to 12004.17
I can start the ball rolling from my faffing about
107MB subD from an STL reduced to 147KB
Size: 550.6 KB, Downloaded: 10 times, Dimensions: 1920x1080px
12004.19 In reply to 12004.18
Hey, I downloaded the STL file and, using Blender with an add-on called “QRemeshify”, I converted it into a quad topology mesh.
Then I exported the model as OBJ and imported it into Moi3D using the SubD command.
I’m attaching the OBJ file below, so you have a model in Moi3D to work on that’s lighter than an STL file.
You can also find QRemeshify on GitHub, but maybe from this link (https://ksami.gumroad.com/l/QRemeshify) you get a version that works with the libraries as well.
However, if you’re dealing with this kind of file, you might want to consider Quad Remesher, which I already mentioned in my previous comment, because it produces a much better remesh.
Show messages: All  1-15  16-19
