Invert and hide in one script?
All  1  2-5
12003.2 In reply to 12003.1
Hi Matedem,
Does this do what you want?
script:moi.geometryDatabase.invertSelection(); moi.geometryDatabase.hide();
1. Select Object(s) to Invert
2. and then Hide
This inverts the current selection first, then hides the newly selected objects — effectively leaving the original selection visible,
EDITED: 20 May by LIGHTWAVE
12003.3
works perfect. tnx!
12003.4 In reply to 12003.2
Hi
And return it to how it was?
12003.5 In reply to 12003.4
Hi Booleano,
There is an Isolate function which will hide everything that is not selected, and also retain a memory of what was hidden and visible before.
When you trigger it a second time it will restore everything to its pre-isolate state.
That is available by right-clicking on the Edit > Hide button, or if you want to put it on a shortcut key use this:
script: moi.geometryDatabase.isolate();
Show messages: All  1  2-5
