Area From Curve Script
12002.1
Here’s a small curve area helper. Select a closed curve and run the command.
It calculates the area, shows the result in a popup, then copies it to the clipboard.
Works from any view.
Other notes/config details are in the text file. May expand later, but working well for now.
Video might follow pending operator firmware updates.
MoI3D CurveArea helper preview
A = π × 150²
A = 70,685.83 mm²
A = 0.0707 m²
Enjoy.
Very nice.
But why use square meters instead of the "unit system" specified in Moi's options?
I model using millimeters, and your function gives me values ​​like 0.00 m².
Moi's detail function also provides the area.
You just need to take the curve, create a plane of it, and then request the area detail.
Your script allows you to get the area more quickly, but I think keeping the "unit system" would be preferable.
Message 12002.3 deleted 20 May by LIGHTWAVE
12002.4 In reply to 12002.2
Hi Phiro, added mode 3. Type or use shortcut:
AreaFromCurve 3
Gives moi native area numbers. Seems to work:
