Pivot Point issue
All  1-12  13-16
11999.13 In reply to 11999.12
Hi Yanus3D, please try the attached .lwo , does it have the LightWave layers how you want?
11999.14 In reply to 11999.13
Yes!
That`s correct export
One layer only.
11999.15 In reply to 11999.14
Hi Yanus3D,
> Yes!
> One layer only.
Great! To get that result, make sure "Combine same named objects" is turned on here under Options dialog > Import/Export :
Then set the objects you want combined to have the same object name before exporting.
To do that, use Ctrl+A to select all, then click on the object name here and set to any name other than blank:
If you then generate your .lwo file you should get the same one layer result.
11999.16 In reply to 11999.15
Yes, that`s works!
So I was thinking (I hate extra clicks in pipeline) is possible to do automatically?
Simple button in LW Exporter for it.....
Show messages: All  1-12  13-16
