Boolean
All  1-2  3-11
11997.3 In reply to 11997.2
Hi Pilou
I don't understand the video you posted.
It has nothing to do with what I want to do.
11997.4 In reply to 11997.1
Hi Booleano, I'm sorry but I'm not understanding very much of this.
First off I'm seeing 6 objects in Green, not 3 like you wrote and the objects are stacked up on top of each other.
Next thing is I don't understand what you mean by doing a boolean difference to a specified dimension. Is it a 4mm radius fillet that you want to have that you are showing in CC.jpg ?
11997.5 In reply to 11997.1
If you're trying to create a "mould" I managed it by putting an exact in-line block for the boolean with the rear section
a single multi-block boolean failed for me
I presume the others would work this way too and then merge them.
11997.6 In reply to 11997.4
Hi, Michael
I apologize for my mistake.
It's true that the 3 objects are duplicated, but to fix it, you just need to delete the extra 3, leaving only 3. Could you delete them? That way I don't have to send you the file again.
11997.7 In reply to 11997.5
Hi ado 1
Como he explicado a Michael, tenĂ­a los 3 objetos duplicados
11997.8 In reply to 11997.6
Hi Booleano,
Sure, but I'm sorry I still don't understand which thing is supposed to be 4mm.
11997.9 In reply to 11997.8
Hi Michael
Esta foto, te lo explica todo
11997.10 In reply to 11997.9
Hi Michael
This photo explains everything
11997.11 In reply to 11997.10
Hi Michael
Why does it have to be done on both sides of the file?
Show messages: All  1-2  3-11
