Browser Toggle Script - Inside to Adjacent
All  1-3  4-5
11993.4 In reply to 11993.3
Hi SUIYAN,
> Is there a version that can be used with V3?
Sorry no the script access to the scene browser was added in MoI V4, that's the minimum version needed for this one.
11993.5 In reply to 11993.4
Hi Suyan, i'd consider V4 so you can use V5 beta and all its improvements when you can.
In the meantime, this is a bit of a hack and it is not a 'toggle key' , Maybe
could be made one although with this version, pointless really as: its floating,
needs adjacent set and then the browser button pressed to minimise (so adjacent
panel is out of view).
So, if you can live with the scene browser floating or have two monitors might be "ok".
- It opens a floating scene browser on a shortcut key.
You would set options scene browser view to adjacent for this one to work.
options>general>scene broswer position>adjacent
Put sidepane_V3_float.htm
file into moi 3 ui folder, here:
The shortcut command is:
script: moi.ui.createDialog( 'sidepane_V3_float.htm', 'resizeable,defaultWidth:260,defaultHeight:820' );
▶ Click to play video
Inspired by this (floating tool palette)
https://moi3d.com/forum/messages.php?webtag=MOI&msg=9758.1
EDITED: 16 May by LIGHTWAVE
Show messages: All  1-3  4-5
