Anime 2D from a SVG Moi File
All  1-7  8-18
11992.8 In reply to 11992.7
Only curves lines can be directly animating from SVG format! Because it's a flat format!
As you can make a 3D projection it's a false "volume" as a flat one! :)
And here it's "progressive" animation... a redrawing of curves lines with effect, speed, colors, reverse, order ....not moving rotating resizing!
You will be able to move and resize in real time by hand!
EDITED: 16 May by PILOU
11992.9 In reply to 11992.8
Hi Pilou, i should have probably said fill not solid.
One for the future maybe
" SVG does have a fill property that allows it to be animated and fade. The fill attribute can be used to define the color or any SVG paint servers like gradients or patterns used to paint the element"
Stefano
11992.10 In reply to 11992.9
Final last release! :)
From any SVG files from Moi3D of course!
https://moiscript.weebly.com/anime-svg.html
Entierely working!
Have fun progressive animations!
EDITED: 17 May by PILOU
My Moi French Site
My Moi French Site
Next will be for make a svg creating file! :)
EDITED: 6 Jun by PILOU
With a Volume inide Moi
-Separate all
- apply the script of visibility... script: moi.geometryDatabase.selectVisible();
- Invert Selection
- Kill the selection
- Join
- Apply a subdivision
- export as OBJ Ngons /minimum polys
- Apply the convert prog wire to 3dm file with closed polylines : https://moi3d.com/resources Obj23dmWireframe converter
- Import result inside Moi
- Export as SVG
EDITED: 31 May by PILOU
A cool process! :)
Michael made a little script who makes the above process very easy! :)
https://moi3d.com/forum/index.php?webtag=MOI&msg=12013.1
English manual is also done! :)
My Moi French Site
OXY my free svg iIlustrator is finished! ;)
Bottom page!
EDITED: 7 Jul 11:33 by PILOU
Show messages: All  1-7  8-18
