Tidy / fun script
This script creates default values for "panel thicknesses"
using the extrude command. It's created to allow you to select
and scroll through default values...no mouse needed.
Check out the animation or select the default values by using the
keyboard arrow keys...
up or down
use enter or right click to select...
To set your default panel values you create a keyboard shortcut
and type panels followed by the values which are space-seperated.
if you work with common stainless steel sheets for example you might create a keyboard
shortcut "p" for panels and type in that shortcut
panels 0.9 1 1.2 1.5
work with wood sheet you might type
panels 9 12 15
work with sign materials you might type
panels 3 5 10 15
etc etc
.jpg)
