Custom fillet with G2 curvature
All  1  2-4
11984.2 In reply to 11984.1
Hi geekmidget, select the inner cone piece and then run the merge command on it (press tab key to put focus in XYZ bottom input that works like a mini command line, then type merge and then <enter>).
Then there will be just one edge on each object, select those and then you can do Blend.
When there are more than 2 edges and they are all touching each other end to end Blend will have some difficulty in automatically sorting them.
11984.3 In reply to 11984.1
You have 2 edges against only one on the surface so.. :) and Micheal is always more speedy than me! :)
And because i don't remember the Merge method :)
so my long method :)
Move Extract the 2 edges + the close circle Edge
Join the 2 edges it's now 2 curves !
Straight Loft the 2 Curves
Replace this repair against the false original
Here with Blend no problem after repair!
EDITED: 7 May by PILOU
11984.4
Awesome, thank you both!
Show messages: All  1  2-4
