Flatten out 3D shape
11983.1
Is there an efficient way to 'flatten out' this shape? I need to get the top profile wire cut and need to have the entire shape flat so I can bend in the curves when I have the blank cut.
11983.2 In reply to 11983.1
Maybe something with the Flow function ?
Draw a line above your object
Project it
Unwrap the curve
Flow function
Difference on the view is perspective optic effect! ;)
11983.3 In reply to 11983.1
Hi Guy, you may need to rebuild the connecting area, it's kind of messy:
That comes from making an offset surface going around a bend where the offset distance is greater than the radius of the bend:
11983.4 In reply to 11983.1
11983.5 In reply to 11983.2
Thanks Frenchy and Michael,
Yes Flow worked nicely once I figured out how it works!
EDITED: 7 May by GUYLUKE
11983.6 In reply to 11983.5
i wonder if the edge flange script could also be adapted to work backwards and/or to take snapshots therefore
effectively having the memory to "unfold"
- not tried this script or flow functionality yet its been on my radar...
link to edge flange script..which i see as "folding tool"
https://moi3d.com/forum/index.php?webtag=MOI&msg=11523.1
