Continue Fillet
11977.1
I only really use MOI to export .fbx from .stp models so dont have much CAD knowledge...on this model, the fillet of one edge doesnt continue down like the other side. Is there any way in MOI to either continue that fillet down or "undo" the fillet above to refillet the whole edge?
If I select the missing filleted edges and try the fillet command, I can only get a fillet at around 3.75mm which is too large?
Any ideas?
Size: 1.2 MB, Downloaded: 60 times, Dimensions: 3225x1744px
Size: 349 KB, Downloaded: 53 times, Dimensions: 1063x805px
11977.2 In reply to 11977.1
Hi ironsight design, is it possible for you to post the .3dm file or e-mail it to me at moi@moi3d.com if you want to keep it private?
It's hard to give advice without being able to examine the geometry.
But if you want to remove a fillet there is a new tool in the v5 beta using shift+delete.
11977.3 In reply to 11977.1
Hi ironsightdesign, also you may need to select more edges for the fillet, it won't want to stop in this spot since that would open up a hole:
