installing plugins in new beta
All  1-4  5-8
11973.5 In reply to 11973.4
Hi Wim, re:
> still having issues with scripts/commands installed in the commands folder
Can please you show the full path of the commands folder you are referring to here?
> I have always, for the last 14 years, copied the .js and .htm files into
> the commands folder, as instructed by Michael
The instructions changed with new capabilities that were set up in version 4 to solve this exact problem.
If you're still following the instructions from version 2.5 or version 3 then you'll keep running into the same problem.
The updated instructions are on the FAQ here.
I investigated the repeated permissions thing on Tahoe, I'll track that down shortly.
11973.6 In reply to 11973.4
Hi Wim,
for this part:
> also, I still have to give permission in a popup window to read/write from/to any
> folder, although I gave permission in the preferences.
There is some discussion on this one here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=11975.1
If you download it again it should be fixed.
11973.7 In reply to 11973.5
Michael,
the full path is:
Macintosh HD ›Applications ›Mol v5 beta Apr-27-2026.app ›Contents ›Resources ›commands
edit: I am sorry, I must have missed the instruction to put plugins and scripts in the command folder in the library when 4.0 came out. Got that now! thanks
kr
wim
EDITED: 25 Jul by WIMVERBE
11973.8 In reply to 11973.7
Hi Wim,
That's not the best place to put plugins: they won't carry over to a new version. A different location exists that survives across versions.
On Mac from a Finder window, go to the menu and pick Go > "Go to folder" and type in:
~/Library/Application Support/Moi/commands
- Peer
Show messages: All  1-4  5-8
