remove 6 edges that don't do anything
11971.1
I can't quite remember how I got these (I was making a cut-out there and maybe removed it badly).
Question 1: how do I remove them? ...they aren't causing any problem per se, but they get in the way of my view as I will be putting another cut-out there.
- I have tried creating a 2nd solid that covers it and boolean-union.
- I have tried to separate and delete them but that doesn't work either (or I'm doing it wrong).
Question 2: Is there a cleanup tool to remove edges that don't impact the surface geometry?
Question 3: related question: If I did create another cut-out there, is there a simple way to resize it (without removing it entirely and creating a new one)? ...I think this may be how I got these edges in the first place.
Any tips greatly appreciated!
Size: 219 KB, Downloaded: 47 times, Dimensions: 763x627px
11971.2 In reply to 11971.1
Hi James, can you please post the .3dm file for the object you show?
11971.3 In reply to 11971.1
Hi James,
In v5 you can use the Transform > Move command on selected faces to edit openings.
Check out here for some demo screencaps:
http://moi3d.com/forum/index.php?webtag=MOI&msg=11803.1
11971.4 In reply to 11971.3
brilliant - thanks.
...just downloaded the latest beta and am playing with it :-)
...are the files backward compatible with v4?
11971.5 In reply to 11971.4
Hi James,
Yes.
If you can please upload the .3dm file that would help me answer your other questions too.
11971.6 In reply to 11971.5
Thanks, Michael.
Here you go.
11971.7 In reply to 11971.6
Hi James, there is a new "RemoveAndFill" function in v5 that can be used for this case.
You can access it by selecting the face:
Then use Shift+Delete:
It's also possible to do an "untrim" to erase a trim boundary to uncover the underlying surface. That's done by separating out a surface so it's not joined and then select all edges of a boundary and use Delete.
Some info on untrim here, but Shift+Delete is more convenient:
http://moi3d.com/forum/index.php?webtag=MOI&msg=444.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=9671.5
11971.8 In reply to 11971.7
thank you!
11971.9 In reply to 11971.7
This I like. That'll make my final cleanups way easier :)
