V5 beta Apr-27-2026 available now Sticky
 1-3  4-23  24-43  44-46
11970.4 In reply to 11970.1
would you like feedback in this thread or as separate posts?
11970.5 In reply to 11970.4
Hi James, separate posts is a bit easier to keep track of.
But either is ok.
11970.6
This releae seems to have had a substantial update to the Shell tool. It's looking very good over here. ;-)
Thank you, Michael.
Martin.
11970.7
Revolve tool doesn't seem to be following the shape of a curved profile I made.
11970.8 In reply to 11970.7
Hi geekmidget, that's just a display artifact that should be ignored.
There is a setting under Options > View > Meshing parameters > "Mesh angle", if you set Mesh angle to 5 it will do some more refinement of the display mesh.
But it isn't very good to modify that if you have larger models because the display meshes can get pretty heavy.
More information here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10580.2
Message 11970.9 deleted 2 May by PEER
11970.10 In reply to 11970.7
It's just a display artifact and is not indicative of any inaccuracy in the part.
Go to Options > View and lower the Mesh angle from 10 to 5 to see the effect.
Martin.
11970.11
Thank you, what a relief!
11970.12
Do we have release notes for this version?
11970.13 In reply to 11970.12
Hi Cuboctahedron,
Not yet, sorry for the delay.
11970.14 In reply to 11970.1
Thanks Michael
11970.15
Would it be possible to have a small summary of the update ?
Marc
11970.16 In reply to 11970.15
Release notes added at top of this thread.
11970.17 In reply to 11970.16
Brilliant thanks Michael and nice weekend..
EDITED: 22 May by LIGHTWAVE
Message 11970.18 deleted 22 May by WIMVERBE
11970.19
Thank you for the all these new features, bug fixes, and scripting additions!
EDITED: 23 May by PEER
11970.20
Thanks for the update Michael !
Marc
11970.21
I don't know if this has been suggested but I will post this anyway.
I use groups to separate different versions of the same set of parts. All the parts that make up version 1 of some assembly, in one group, all the parts for version 2 into another group, etc..
I would like to see a feature where a group (via the group header) could be assigned some information, such as a version number.
Then for each item within the group, when setting the name, you could use as tag like %V which would be replaced with the version number.
This would mean when creating a new version I would only have to copy the group and set an appropriate version number for the group and all of the parts in the group would display the new version number.
This would be a great help to me as now have to edit the name of each part in the group.
Frederick
11970.22 In reply to 11970.21
Hi Frederick,
I think there are enough pieces in place to do this now.
The "assign some information" is done by selecting the top level group, push the "Details..." button, and in the Object properties dialog expand the "Object user text" section and add in a new entry, for the Key part put in "fcwilt_version" for the value part put in your version number.
So looks something like this:
For this part:
On each child item inside the group you could assign a user text of fcwilt_name_template and give it a value with a %V in it, like: "The version is %V".
Then you need a script that when triggered will go through all top level groups and if it has a fcwilt_version data chunk in the top level group's object user text the script will go through the child objects of the group and any child that has a fcwilt_name_template it will evaluate the template replacing the %V and then set the object name to the resolved text.
If that sounds like it does what you need I can cook up the update script for you , it should not be very difficult.
That's what the Object user text is for, so scripts have a channel to store data that is for their own needs which gets saved and loaded. There is also document level user text you can find under File > Notes > Document user text.
11970.23 In reply to 11970.22
Hey Michael,
You never cease to amaze.
I would like to see such a script as it does sound like it may well do the job.
I don't quite fathom how a "tag" in the name will get replaced without losing the tag needed for a any subsequent version.
I was thinking that the tag would have to be kept in the entered name but any time the "complete" name was needed for display, export, etc. the replacement would happen behind the scenes
Thanks much.
Frederick
Show messages:  1-3  4-23  24-43  44-46
