V5 beta Apr-27-2026 available now Sticky
 1-10  11-30  31-46
11970.11
Thank you, what a relief!
11970.12
Do we have release notes for this version?
11970.13 In reply to 11970.12
Hi Cuboctahedron,
Not yet, sorry for the delay.
11970.14 In reply to 11970.1
Thanks Michael
11970.15
Would it be possible to have a small summary of the update ?
Marc
11970.16 In reply to 11970.15
Release notes added at top of this thread.
11970.17 In reply to 11970.16
Brilliant thanks Michael and nice weekend..
EDITED: 22 May by LIGHTWAVE
Message 11970.18 deleted 22 May by WIMVERBE
11970.19
Thank you for the all these new features, bug fixes, and scripting additions!
EDITED: 23 May by PEER
11970.20
Thanks for the update Michael !
Marc
11970.21
I don't know if this has been suggested but I will post this anyway.
I use groups to separate different versions of the same set of parts. All the parts that make up version 1 of some assembly, in one group, all the parts for version 2 into another group, etc..
I would like to see a feature where a group (via the group header) could be assigned some information, such as a version number.
Then for each item within the group, when setting the name, you could use as tag like %V which would be replaced with the version number.
This would mean when creating a new version I would only have to copy the group and set an appropriate version number for the group and all of the parts in the group would display the new version number.
This would be a great help to me as now have to edit the name of each part in the group.
Frederick
11970.22 In reply to 11970.21
Hi Frederick,
I think there are enough pieces in place to do this now.
The "assign some information" is done by selecting the top level group, push the "Details..." button, and in the Object properties dialog expand the "Object user text" section and add in a new entry, for the Key part put in "fcwilt_version" for the value part put in your version number.
So looks something like this:
For this part:
On each child item inside the group you could assign a user text of fcwilt_name_template and give it a value with a %V in it, like: "The version is %V".
Then you need a script that when triggered will go through all top level groups and if it has a fcwilt_version data chunk in the top level group's object user text the script will go through the child objects of the group and any child that has a fcwilt_name_template it will evaluate the template replacing the %V and then set the object name to the resolved text.
If that sounds like it does what you need I can cook up the update script for you , it should not be very difficult.
That's what the Object user text is for, so scripts have a channel to store data that is for their own needs which gets saved and loaded. There is also document level user text you can find under File > Notes > Document user text.
11970.23 In reply to 11970.22
Hey Michael,
You never cease to amaze.
I would like to see such a script as it does sound like it may well do the job.
I don't quite fathom how a "tag" in the name will get replaced without losing the tag needed for a any subsequent version.
I was thinking that the tag would have to be kept in the entered name but any time the "complete" name was needed for display, export, etc. the replacement would happen behind the scenes
Thanks much.
Frederick
11970.24 In reply to 11970.23
Hi Frederick,
The "tag" would need to be stored separately from the name, in a user text slot.
But it looks like there is a bug with setting user text on groups, it looks like that will need to be cleared up first before this will work.
11970.25 In reply to 11970.24
Thanks for the feedback.
Frederick
11970.26
If a tool is triggered via shortcut, some but not all of the parameters are reset to default values, which is different from triggering it in the UI. Affects may tools, but here's an example using the Text tool, once triggered via the UI, once via a shortcut: https://avm-cdn.com/images/moi5_shortcut.mp4
11970.27 In reply to 11970.26
Hi summarity,
I should be able to fix that but you can solve it now if you put in "text" with all lowercase letters as the command name for the shortcut key.
Basically what happens right now is the UI says to run the "text" command, while the shortcut key says to run the "Text" command. They do both end up running the same actual command but the different upper/lower cases makes them have different storage for default values.
11970.28
Dear Michael,
I'm loving v5 beta. Having groups for example makes MoI3d superb to work with and is the answer I've been hoping for for years, finally knowing that there is an alternative to both SketchUp as well as Rhino. Full marks to that!
However, and I don't know if this is planned and I apologise if this isn't the correct place to raise this topic, but something I'd like to see in v5 of Moi3d is better window management.
Right now and in order to have several windows open at the same time results in many floating windows.
Would it not be better to have a tab-based system where there is one main window, but different models on different windows in tabs for easier desktop management?
For those who don't mind multiple windows- for eg multiple monitor setups- there could be the option for both? Or that tabs could simply be 'pulled out' like is possible in most major browsers and window management in Apple's Finder. Same I believe in Windows.
Keep up the great work!
Tom
11970.29 In reply to 11970.28
Hi Tom, managing multiple top level windows is really a job that should be handled by the operating system rather than by each individual app.
For example on Windows the operating system does things like having separate entries in the taskbar when there is a small number of top level windows for the same app, and collapsing that to one entry in the taskbar when there are more.
Unfortunately the infrastructure on Mac to do this requires all the "document tabs" and the single main window to all be running inside of a single process.
The problem with that is if there is a crash it will take out everything instead of keeping the crash contained to just one window.
Currently on Mac each MOI window is in its own separate process so you get a big boost in stability where a crash in one window does not interfere with any other windows. Hopefully at some point Apple will make the operating system handle multiple app windows in separate processes better than it does currently.
I don't know the Mac system but on Windows you can start several sessions in the same time! ;)
My Moi French Site
Show messages:  1-10  11-30  31-46
