Connect two faces
All  1-7  8-10
11968.8 In reply to 11968.7
> What is the "Multi Blend Edges" ?
It's when you select multiple edges along either or both sides instead if only one edge on each side which used to be a limit some time ago.
> A script or just the normal way to use the Blend function ?
It's built in to the regular Blend command.
11968.9 In reply to 11968.4
> you an also use Sbridge then Subdive beta 9 but depends of what do you want exactly! :)
I can do... what?
11968.10 In reply to 11968.9
Something like this! :)
(i have shortcuts for the Functions SBridge and SubDiv beta9 so direct result)
Show messages: All  1-7  8-10
