Connect two faces
All
1-3
4-10
Frenchy Pilou (PILOU)
24 Apr (4 of 10)
11968.4
you an also use Sbridge then Subdive beta 9 but depends of what do you want exactly! :)
My Moi French Site
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BurrMan
24 Apr (5 of 10)
11968.5
In reply to
11968.3
Michael,
I had to test it, but your added "Multi Edge Blend" works in this case with the seperate edges. So I deleted the 2 faces, selected show naked edges and ran blend!... Poof! Voila!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
25 Apr (6 of 10)
11968.6
In reply to
11968.5
That's great Burr, I had forgot that it can do more than 2 edges at a time now.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
25 Apr (7 of 10)
11968.7
What is the "Multi Blend Edges" ?
A script or just the normal way to use the Blend function ?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
25 Apr (8 of 10)
11968.8
In reply to
11968.7
It's when you select multiple edges along either or both sides instead if only one edge on each side which used to be a limit some time ago.
It's built in to the regular Blend command.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Andre
30 Apr (9 of 10)
11968.9
In reply to
11968.4
I can do... what?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
1 May (10 of 10)
11968.10
In reply to
11968.9
Something like this! :)
(i have shortcuts for the Functions SBridge and SubDiv beta9 so direct result)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-3
4-10
