Connect two faces
All  1-2  3-10
11968.3 In reply to 11968.1
Hi Andre, just to illustrate what Burr wrote - these are the faces to delete:
Then you can select 2 edges like this and run Construct > Blend to make a blend surface:
The reason to delete the faces is to control which surface the blend will be smooth to. When it is a joined edge shared between 2 surfaces it doesn't know which of these possible directions to use:
You want the face to be removed so the edge only belongs to one face.
you an also use Sbridge then Subdive beta 9 but depends of what do you want exactly! :)
My Moi French Site
11968.5 In reply to 11968.3
Michael,
I had to test it, but your added "Multi Edge Blend" works in this case with the seperate edges. So I deleted the 2 faces, selected show naked edges and ran blend!... Poof! Voila!
11968.6 In reply to 11968.5
That's great Burr, I had forgot that it can do more than 2 edges at a time now.
What is the "Multi Blend Edges" ?
A script or just the normal way to use the Blend function ?
11968.8 In reply to 11968.7
It's when you select multiple edges along either or both sides instead if only one edge on each side which used to be a limit some time ago.
It's built in to the regular Blend command.
11968.9 In reply to 11968.4
I can do... what?
11968.10 In reply to 11968.9
Something like this! :)
(i have shortcuts for the Functions SBridge and SubDiv beta9 so direct result)
Show messages: All  1-2  3-10
