Cmorph with distance?
All  1-4  5-15
11964.5
This is the situation I would need.
Tnx!
Size: 47.6 KB, Downloaded: 40 times, Dimensions: 584x344px
11964.6 In reply to 11964.5
So like slicing a 3d model in a single direction with no "curve"
I did a jury rig, by using LineWeb to generate a single line then ran calculator to divide it by my tooldiameter to get the number to enter into the morph and generate spacing that was close.
The "Close" came into play because if my line was 6.8824 and i divided it by .5, i got 13.7648, but linemorph only allowed me to enter 13 or 14. So slightly smaller or slightly bigger than .5 tool. A little smaller could work if your step didnt need precision at the perfect level
It seems like this could be scriptable (I am not capable but there are those who could)
If you need the perfect steps of .5, this is what your CAM software does with complex toolpath calcs and algo's.
11964.7 In reply to 11964.6
In other words, it is more like a "Loft that creates curves instead of surfaces"!
MultiISO Could also be used to generate those loft curves. It seems that what is missing will be an automatic calc of the distance of the loft to get a count value to use.
i wonder If a script could do the step distance calc to get the count value?
I wonder if MoI's Loft Command could generate "Curves instead of Surfaces and solids"?
EDITED: 15 Apr by BURRMAN
Project can be cool too! ;)
And as history is enabled by default you can adjust like you want!
Here one curve but you can move any number of curves in the same time !
11964.9 In reply to 11964.5
Hi Matadem,
Please try the attached version. This one will show the step distance if all the curves are planar.
11964.10
Nice!
That is exactly what I needed.
Now I can get things done faster.
Thank you!
Are you sure that "distance" is working ?
Number keeps the control!
My Moi French Site
11964.12
Script shows 1.8...measures at 1.75mm
Good enough for me.
Size: 39.7 KB, Downloaded: 32 times, Dimensions: 569x571px
11964.13 In reply to 11964.11
It was working in my tests. If you have a case where it isn't working can you post the .3dm model file?
Sorry not understanding this part.
11964.14 In reply to 11964.13
Despit of any Distance entered number of curves is the only thing that work!
But maybe i don't understand what Cmorph2 is supposed to do!
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/morph2.3dm
11964.15 In reply to 11964.14
For this version that's normal. The request was to have the value displayed, not edited.
Show messages: All  1-4  5-15
