Boolean
All  1-4  5-11
11960.5 In reply to 11960.2
Hi
This is what I get when I click on the "Wire" and "Wire2" icons.
Please create a file with the three objects so I can see how it's done.
Size: 50 KB, Downloaded: 38 times, Dimensions: 593x509px
11960.6 In reply to 11960.5
Hi Booleano, that is saying that the Wire command wasn't found.
Does it work if you push Tab and then type _wire (with starting underscore) and push Enter?
If that works then you need to update your SidePane1.htm dialog box to have command="_Wire" (underscore at the start) instead of command="Wire". Same for _Wire2
Else works fine! ;)
My Moi French Site
11960.8 In reply to 11960.7
Hi Pilou
It's fixed now.
P.S. Your render is beautiful, how did you do it?
EDITED: 5 Apr by BOOLEANO
11960.9 In reply to 11960.8
Hi Booleano, that message you are getting says that the Wire command wasn't found.
11960.10 In reply to 11960.8
As you see i have hundred of scripts intalled !:)
2 possibilities (for me) to Access
You have 2 more possibilities
- make a shortcut with _wire or _wire2 in the second column
or Press Tab and write _wire or _wire2
A big list alphabetical (my favorite) or an list of Images using follow for make the same than your but not practical! :)
as you see i have not image for the specific "Wire" ;)
Ps and more for me it's inFrench! :)
If you have your message it's because as Michael said you have not your Script installed ! in the commands folder!
Must be for Windows in the folder Roaming Moi / commands / _wire.htm & _wire.js ..._wire2.htm & _wire2.js
I suppose that will works also if they are in the direct Program / Moi/ commands
EDITED: 5 Apr by PILOU
11960.11 In reply to 11960.10
It's either that, or if it is installed you've got the wrong name for it in your dialog box.
The button in your dialog box has command="Wire" but the actual file name is _Wire with an underscore in front.
Show messages: All  1-4  5-11
