How to rotate direct after copy
All  1  2-4
11955.2 In reply to 11955.1
Hi Matadem,
> If you select an item copy it click and you can move the copy.
You mean you can press the mouse down on the copy and drag it?
> but if you copy you can't rotate direct after...or I am missing something here?
You will need to set selection on the copy first to get a rotation grip.
11955.3 In reply to 11955.2
Rotate command as attached.
Tnx!
Size: 233.2 KB, Downloaded: 33 times, Dimensions: 929x701px
11955.4 In reply to 11955.3
Hi Matadem, if you want to do a combination of Copy + Rotate, the Transform > Orient and Transform > Orient > Line to line commands do that:
https://moi3d.com/4.0/docs/moi_command_reference8.htm#orient
https://moi3d.com/4.0/docs/moi_command_reference8.htm#orientlinetoline
Show messages: All  1  2-4
