How to rotate direct after copy
11955.1
Good day.
If you select an item copy it click and you can move the copy.
but if you copy you can't rotate direct after...or I am missing something here?
Tnx!
11955.2 In reply to 11955.1
Hi Matadem,
You mean you can press the mouse down on the copy and drag it?
You will need to set selection on the copy first to get a rotation grip.
11955.3 In reply to 11955.2
Rotate command as attached.
Tnx!
Size: 233.2 KB, Downloaded: 33 times, Dimensions: 929x701px
11955.4 In reply to 11955.3
Hi Matadem, if you want to do a combination of Copy + Rotate, the Transform > Orient and Transform > Orient > Line to line commands do that:
https://moi3d.com/4.0/docs/moi_command_reference8.htm#orient
https://moi3d.com/4.0/docs/moi_command_reference8.htm#orientlinetoline
