Boolean
All
1-8
9-13
BurrMan
26 Mar (9 of 13)
11949.9
In reply to
11949.8
Pretty sure its "sScale" you can find here:
http://moi3d.com/wiki/MaxScriptArchive
then how to use it:
You need to have box model which will still show points. Basically part of Max's SubDiv work back in the day....
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BurrMan
26 Mar (10 of 13)
11949.10
In reply to
11949.8
Not really what you asked for but a fun connection!
The command is called "Wires"....
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
26 Mar (11 of 13)
11949.11
In reply to
11949.8
Yep I have made a mistake Burr is right!
But... sScale can resize the selected faces by their points! ;)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Booleano
27 Mar (12 of 13)
11949.12
In reply to
11949.9
Hi BurrMan, could you send me that file? That way I'd understand it better. I'm Spanish. Thanks.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BurrMan
27 Mar (13 of 13)
11949.13
In reply to
11949.12
The original file written by max is here (Look for Wire name):
https://moi3d.com/wiki/MaxScriptArchive
I am using a modified version by mkdm found here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=8301.27
The mkdm version allows to pre-select an alternate profile. If no profile selected, it just uses a circle....
EDITED: 27 Mar by BURRMAN
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-8
9-13
