Boolean
All  1-6  7-13
11949.7 In reply to 11949.5
Hi Booleano, your question was:
> but when using the "sBridge" function, I can't get these two "red lines" to join together, forming the
> object's handle. What would be the correct process to achieve this?
With your object like this:
If you want to make a result like this as you already have in the posted file:
You could get that by drawing in 2 lines in the side view like this:
Then select the object and run Boolean difference, using the lines as the cutting objects.
Delete these pieces:
Then select these for _sBridge:
Another way is you can select this face:
Run Transform > Rotate > Rotate Axis, click 2 points across the middle of the face for the rotation axis:
After you have placed the axis, type 45 and push Enter to rotate it by 45 degrees:
Repeat on the lower one but with negative 45 (-45) degrees.
11949.8 In reply to 11949.6
Hi Pilou
Sorry, but I don't have the sSize script. Could you send it to me and explain what it does?
Thanks again.
11949.9 In reply to 11949.8
Pretty sure its "sScale" you can find here:
http://moi3d.com/wiki/MaxScriptArchive
then how to use it:
You need to have box model which will still show points. Basically part of Max's SubDiv work back in the day....
11949.10 In reply to 11949.8
Not really what you asked for but a fun connection!
The command is called "Wires"....
11949.11 In reply to 11949.8
Yep I have made a mistake Burr is right!
But... sScale can resize the selected faces by their points! ;)
11949.12 In reply to 11949.9
Hi BurrMan, could you send me that file? That way I'd understand it better. I'm Spanish. Thanks.
11949.13 In reply to 11949.12
The original file written by max is here (Look for Wire name):
https://moi3d.com/wiki/MaxScriptArchive
I am using a modified version by mkdm found here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=8301.27
The mkdm version allows to pre-select an alternate profile. If no profile selected, it just uses a circle....
EDITED: 27 Mar by BURRMAN
Show messages: All  1-6  7-13
