Untrim not working
All  1-7  8-10
11944.8 In reply to 11944.3
Hi SebKaine,
> - untrim the patch
> - recreate a new projection curves by rebuilding the actual contour curves but without the font
> - then reproject the reconstructed curves and trim again ?
Yes, but you can trim with the edges of the neighboring faces, you don't need to do a separate projection step.
So after separating out the face, select this trim boundary (select 1 edge then Ctrl+a):
Delete and you'll have the underlying surface:
Select it and run Edit > Trim, and select the neighboring edges as the cutting objects:
Don't forget this little edge here:
Inside the Trim command select these pieces to discard:
Result:
11944.9 In reply to 11944.8
Thanks a lot for the very detail answer Michael !
This is maybe more precise than mine but maybe less speedy ! :)
Show messages: All  1-7  8-10
