Question about 3d printing my spaceship concept
All  1  2-9
11942.2 In reply to 11942.1
Hi Nikola, the best way to export can be different depending on the particular printer being used so it is probably best to ask the service where you will be sending the parts to be printed what they want. Some may want the CAD model.
But for general advice especially for stl export you would usually want to have different parts be separated in the STL file, not positioned in place where they are touching each other.
STL format is pretty primitive, it's just a big heap of triangles without any connectivity information. So when multiple parts are overlapping the same space with each other it is difficult for the receiving software to figure out which part a particular triangle belongs to.
11942.3 In reply to 11942.1
Needs of printer and process
Can view it this way. Simplified breakdown
Stl= a null file format. No object separation/organization info… no surface info. just straight to printer
Obj= part and component info. Color and material info. Topology options for reducing face count (?) more advanced printing instructions
11942.4
I would separate the parts it even more.
the reason if it fails you are not messing everything.
Always used stl files no problems.
both Prusa slicer and orca slicer are good.
the one advice I would give if you want to print allot get 2 identical printers.
I went thru hell with only 1 printer and break just when I need it lol...by the time I get the part and if it is the correct one ...weeks gone by.
Now I have 2 new ones and one went bad already but at least I can continue. I want one more and I am good.
You have many infos about 3D Printing in this spacialized site!
https://www.sculpteo.com/
My Moi French Site
11942.6 In reply to 11942.2
Thank You Michael for your valuable advice :)
11942.7 In reply to 11942.4
Thank You Matadem for your valuable advice :)
11942.8 In reply to 11942.3
Thank You BurrMan for your valuable advice :)
11942.9 In reply to 11942.5
Thank You Frenchy Pilou I will check it out :)
Show messages: All  1  2-9
