Merge UV Maps
All  1  2-3
11941.2 In reply to 11941.1
Hi Yanus3D, usually UV mapping would be done in a poly modeling program. MOI does provide a simple automatic mapping where each surface maps to the entire 0,0 to 1,1 unit square.
Depending on what poly modeling software you are importing into there is often a function "separate islands" that will separate those out so they don't refer to the same area.
11941.3 In reply to 11941.2
Thanks!
Meanwhile I got from our community simple script for Lightwave which merge all channels! so no problem!
Show messages: All  1  2-3
