How would you model this?
All  1-3  4-9
11940.4
@Burrman
Close the bottom part I am wondering as well how this would be done I am guessing cutting and blend?
11940.5 In reply to 11940.4
With the pieces i made, after getting the shapes better and design closer, i would boolean parts together to see if fillet can give the desired result. If i needed more “melty” look i would gap the intersections and run blend. If the desired blends cant be achieved at this stage, keep the shape and then process more in a sculpt program after modeling is done, as long as those final poly op’s were end of the line for the pipeline.
Try of a Nano Banana prog... inside free Code Pen https://codepen.io/
Must be interactive but not yet found the good iFrame! ;)
Else
https://codepen.io/The-Schmoll/full/azmZXgb Drag & Drop 2 images
EDITED: 8 Mar by PILOU
11940.7 In reply to 11940.6
You are killing a baby otter every time you generate an AI slop dude !
11940.8 In reply to 11940.7
This is why we must improve the performance of artificial intelligence without delay. ;)
My Moi French Site
11940.9 In reply to 11940.7
Ai….. the Emperor has no cloths!
Show messages: All  1-3  4-9
