How would you model this?
11940.1
Good day.
so I am practicing to model some items I usually not do.
most of what I do is mechanical simpler items.
Correct me If I am wrong
red and orange shapes then network?
how would I tackle the blue part?
the purple I am guessing draw the shape sweep, then cut the front part?
Tnx!
Size: 58 KB, Downloaded: 113 times, Dimensions: 476x472px
11940.2 In reply to 11940.1
I'll bite!
Here is a quick mock up eyeballing the pic in the forum.
2 spheres. A couple curves for more shapes and a couple boolean cuts
It gives me an idea of how it looks.
Another free method for the fun...
Free Rodin
Moi SubD Create from File OBJ
One Image of screen Moi (of course you can hide edges if wanted)
Inside Nano Banana 2 + falseTextures asked
File 3Dm for any modification
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/plane.zip
All can takes 15 minutes!
True textures :)
<img src="https://images2.imgbox.com/60/d4/0UflovwQ_o.jpg
Look at the bottom page the funny video! https://moiscript.weebly.com/nano-banana.html
EDITED: 6 Mar by PILOU
11940.4
@Burrman
Close the bottom part I am wondering as well how this would be done I am guessing cutting and blend?
11940.5 In reply to 11940.4
With the pieces i made, after getting the shapes better and design closer, i would boolean parts together to see if fillet can give the desired result. If i needed more “melty” look i would gap the intersections and run blend. If the desired blends cant be achieved at this stage, keep the shape and then process more in a sculpt program after modeling is done, as long as those final poly op’s were end of the line for the pipeline.
Try of a Nano Banana prog... inside free Code Pen https://codepen.io/
Must be interactive but not yet found the good iFrame! ;)
Else
https://codepen.io/The-Schmoll/full/azmZXgb Drag & Drop 2 images
EDITED: 8 Mar by PILOU
11940.7 In reply to 11940.6
You are killing a baby otter every time you generate an AI slop dude !
11940.8 In reply to 11940.7
This is why we must improve the performance of artificial intelligence without delay. ;)
My Moi French Site
11940.9 In reply to 11940.7
Ai….. the Emperor has no cloths!
