Cut and close at an angle
11938.1
Hi, I have the backrest of an upholstered chair here. For formal reasons, I would like to cut the front ends at an angle so that they match the furniture frame.
Now I have cut the round shape at an angle. When I finish it with “nSided,” there is no clear angle (20°) left. As you can see from the side.
How can I solve this better?
Best, Mala
11938.2 In reply to 11938.1
Where is the 3dm file ?
Generally some curves with Network will make that you want with more control ! ...
Message 11938.3 deleted 28 Feb 9:37 by MALA
11938.4
Here is the moi file. Don´t know why it wasn´t attached...Mala...
P.S.: Get: "Failed to upload: seat moiforum.3dm - Out of attachment space"
11938.5
ok - new try...let´s see...NO cannot upload - it is 1.2k
11938.6
ok - got it...Mala
11938.7 In reply to 11938.6
I capped the end and filleted the result.
Martin.
11938.8 In reply to 11938.4
Hi Mala, for this part:
That means that your file attachment space on the forum here is full.
There is a limit of 50MB of attachment space per user, to help avoid having the web server get totally filled up. If you have hit this limit you'll need to delete some of your previous attachments before you'll be able to upload more.
You can do that by clicking "Options" on the Top and then "Attachments" on the left side menu.
