Extrusion fails
All  1-4  5-12
11932.5 In reply to 11932.4
Sure Michael will answer for this particular case! :)
My Moi French Site
11932.6 In reply to 11932.1
HI Mala,
> Why can't this structure be extruded?
Extrude works on either curves or single surfaces (or also on faces selected on a solid which will automatically boolean with the solid).
Your object is neither of those, it is a "joined surface" made up of 2 surfaces joined together.
To extrude it, select it and run Edit > Separate. Then select the 2 surfaces and run Construct > Extrude.
Since the surfaces are not planar it will default to extruding in the z axis direction which would make a degenerate object so you will need to use the "Set dir" option and pick 2 points to define a valid extrusion direction.
Also note that if you want a result that has uniform thickness you should use Construct > Offset > Shell instead of Extrude. You don't need to separate it first if using Shell.
EDITED: 21 Feb by MICHAEL GIBSON
11932.7 In reply to 11932.4
@pafurijaz
> But why when a face is joined to another they don't have the same normal orientation?
They do, and there isn't any wrong direction on this object.
@Pilou, why do you think there is a wrong direction here?
11932.8 In reply to 11932.7
The fact that extrude works for both in the same time only when on face is flipped...
11932.9 In reply to 11932.8
It doesn't do that.
Flip can flip the direction of selected curves or a surface or entire joined surface.
It doesn't do anything on a face selection.
Extrude does work on this if one or both faces are selected, without any flipping.
However extruding a face selection also tries to do a boolean with the extrusion and that won't work very well if the object isn't a solid. You can turn off the boolean by setting the "Keep separate" option.
So select one or both faces, use "Set dir" and set "Keep separate", should work - no flipping needed.
11932.10 In reply to 11932.9
Thanks for the precisions!
But curious!
My Moi French Site
11932.11 In reply to 11932.10
Hi Pilou, that's all normal behavior.
> Just Flip one face
Does nothing
> Select All
https://moi3d.com/4.0/docs/moi_command_reference6.htm#selectall
quote:
If sub-objects are selected, the selection will be limited to other sub-objects. For example, if you have an edge of a solid selected, this will select all edges of that solid and not other objects.
11932.12 In reply to 11932.11
THx for the precision : so a selective selection! :)
My Moi French Site
Show messages: All  1-4  5-12
