MOI v5 beta boolian diff issue?
All  1  2-13
11928.2 In reply to 11928.1
Hi Guy, it looks like the cutting object is not quite aligned with the base object, like here:
11928.3 In reply to 11928.1
There's also a kind of thin needle area on the base object here:
11928.4 In reply to 11928.1
This attached version should boolean ok now but there is still that little slivery piece, I'll see if I can remove that.
11928.5 In reply to 11928.4
Thank's Michael. How are you seeing those needle alignment issues? I zoom in and it looks fine. I set the mesh angle to 3 and I still can't see them.
11928.6 In reply to 11928.5
Hey Luke,
I didnt see it either. I think it is a "post boolean" item. Not pre boolean
If you zoom to where your green object is "Supposed" to touch with the other object in the front view, you can see the gap that would create a tiny sliver.
I zoomed in to make that gap large enough, then selected the green object and used the edit frame to drag its size to snap the other object, then I did the boolean.
11928.7 In reply to 11928.5
Hi Guy, re:
Yeah like Burr writes above it seems to be after the boolean.
11928.8
Got another diff issue. I'm trying to diff the green screw thread with the main body to leave a female screw thread but when I diff it the entire body disappears.
11928.9 In reply to 11928.8
Hi Guy, coiled objects like your screw thread here can be difficult due to the underlying surfaces overlapping each other from one coil to the next.
Try with the attached version, I split your thread object into 4 quadrants using Edit > Trim and then used ShrinkTrimmedSrf on it.
EDITED: 22 Mar by MICHAEL GIBSON
11928.10
Thanks Michael,
Why did you have to split the thread into object into 4 quadrants?
11928.11 In reply to 11928.10
Hi Guy,
Because that removes the condition that is failing which has something to do with having underlying surfaces that overlap each other.
11928.12 In reply to 11928.10
Hi Guy,
Another trick is to scale everything so that the size of the threaded object is around 50 units (rather than 6 mm), do the boolean, and then scale it back down.
- Peer
11928.13 In reply to 11928.12
Ahh that's easier, thank you.
Show messages: All  1  2-13
