Remove unuses styles?
All  1  2-8
11925.2 In reply to 11925.1
Hi Blackbird, File > Export will write only used styles to the file.
So one way you can do that currently is to select all objects and use File > Export to write out selected objects to a .3dm file and then load that back in with File > Open.
I'll see about adding it to the Style tools menu too.
11925.3 In reply to 11925.2
I am sure I have seen a PurgeUnusedLayer script somewhere…
www.jameselliott.co.uk
11925.4 In reply to 11925.3
Hi James,
Found it:
https://moi3d.com/download/scripts/PetrsMoiPage/PetrsMoiPage.htm#PurgeUnusedLayer
11925.5 In reply to 11925.3
Marble for the win!
(Edit: Missed it by that much....)
11925.6 In reply to 11925.5
thx for the script file.
11925.7 In reply to 11925.6
"""""""""thx for the script file."""""""""""
Sure BlackBird!
Note to those reading forum to understand the software better:
I put the scripts into a js file and it then allows me to keep organized better. It keeps my ini file more compact as i move forward. Max's custom UI then created a popup window which visually shows me all my "commands"! So helpful to remember what you have. Someday, Michael will create the "commands manager", which will replace that temporary function.
So if you follow the link Michael posted, there are several "scripts" written. These also pop into the forum discussion regularly. These are meant to put into a shortcut key and commanded there.
MoI internally handles "scripts and commands" differently. In process. outside of process... A bunch of descriptions i am not totally familiar with, but they affect how MoI executes things with relation to "immediate and forget.... Process is aware" and other explanations (Michael has explained the whole thing in the past, for techy understanding)
So Michael had setup second folder where this can be split naturally, MoI comes with "commands" folder. It can also have a "scripts" folder where the "execute and forget" process directive occurs.
You can take any script and put it a text editor and save it with "js" extension. You now have object to manage outside of ini file. I prefer this.
They can all go into commands folder. But you can benefit by trying to keep things separate.
All of this is excess and not necessary!
11925.8 In reply to 11925.7
Following on BurrMan's thoughts and suggestions, if you would like to have a script or commands manager but do not have Max's custom UI, here's one:
https://moi3d.com/forum/messages.php?webtag=MOI&msg=10353.1
--Larry
Show messages: All  1  2-8
