oderCurves command - correct nomenklatur?
11924.1
I have used the command to reverse several times. In my personal MOI WIKI, I have noted the command as > orderCurves <. However, it does not respond. I cannot find my thread on this topic here. Question: Is orderCurves the correct nomenclature?
11924.2 In reply to 11924.1
Hi Mala, yes it's called OrderCurves, you can get it here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9781.5
11924.3 In reply to 11924.2
I couldn't figure out the detailed workflow from the linked post and videos. I remember that it is so simple, normally.
What am I doing wrong?
1. Activate the spline
2. Press Enter or select it, then enter OrderCurves in the input window under the coordinates.
3. The direction arrows of the spline should be visible. - BUT - I can't see them. I could a few weeks ago. Hmmmm...what am I doing wrong?
11924.4
The script was no longer in the program folder. My mistake. Sorry for the alarm.
