Changing dimension display accuracy
All  1-4  5-7
11923.5 In reply to 11923.4
Thank you. I've been using Options -> General -> Decimal display, which does not affect dimensions.
Now I see how to do it.
11923.6 In reply to 11923.5
Also note :
Changes in Options are not "retroactive" and will not apply to already set Dimensions and this is ok but if you have already set several Dimensions and also want them to be changed and don't want to redo everything to make that change, use Browser, Types, Annotations to select only the Dimensions then click on Details and change all Dimensions at once.
11923.7 In reply to 11923.5
Hi sos,
That one under Options > General > Decimal display controls the program UI, like the radius field in the circle command for example.
Dimensions have their own settings separate from that. You can control the default properties that are applied to a newly drawn dimension by editing the preset properties under Options > Dimensions.
If you want to change the display properties on an already existing dimension that's done by selecting it and using the "Details..." dialog.
Show messages: All  1-4  5-7
