Add "Make corner point" as a shortcut key?
All
1
2-5
Frenchy Pilou (PILOU)
29 Jan (2 of 5)
11915.2
In reply to
11915.1
Press CTRL when you click a point ! You win a shortCut!
For avoid to recall the fonction Curve , enable repeat case...
For close the function press Right Click, Right Click again for recall the function if repeat is not enabled!
EDITED: 29 Jan by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BEANZVISION
29 Jan (3 of 5)
11915.3
In reply to
11915.2
Oh my god! You sir are a legend! Thank you so much :)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Mik (MIKULAS)
29 Jan (4 of 5)
11915.4
In reply to
11915.3
Many "hidden secrets" can be found at
https://moi3d.com/4.0/docs/moi_command_reference.htm
Hope this helps.
Mik
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BEANZVISION
29 Jan (5 of 5)
11915.5
In reply to
11915.4
Thanks Mik, I'll check it out! :)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1
2-5
