Pipe-Script?
All  1  2-8
11911.2 In reply to 11911.1
https://moi3d.com/download/scripts/PetrsMoiPage/PetrsMoiPage.htm#Pipe
Not sure it does all the requested feature tho ?
(one nice addition would be to have a extend distance option to create pipe longer than the input curves on both side, it can help to trim surface later for manual filleting / blending)
11911.3 In reply to 11911.1
Hi BlackBird,
> Creating profiles on the curves is time consuming. Compared to use a pipe-script.
For sweep you don't have to put the profile on each rail, if you position the profile a little bit away from the rail (outside of the rail's bounding box) it will use auto place mode:
11911.4 In reply to 11911.2
""""""""(one nice addition would be to have a extend distance option to create pipe longer than the input curves on both side, it can help to trim surface later for manual filleting / blending)""""""""
There was also the "Wires" script from Max, with an updated version named Wires2 from mkdm
The wires 2 script allows picking a "Profile curve" and includes the "Extend" function you describe
However, it DOESNT do what pipes does, by using a PATH. Only tangent connection to 2 pick points
If somebody could "COMBINE" these 2 scripts, it would do exactly what is requested.
I am not capable of that. Always tried to avoid asking Michael to do extra work
https://moi3d.com/forum/index.php?webtag=MOI&msg=8301.27
EDITED: 19 Jan by BURRMAN
11911.5 In reply to 11911.3
Oh... i didn't know that... i thought i have to place the profile exactly on the rail...
11911.6 In reply to 11911.3
haha its easy i dont know it work like that :D
11911.7 In reply to 11911.4
Thanks Burr, I will check if AI can be useful for once and merge the feature !
11911.8 In reply to 11911.7
Thank you PaQ…
The ole HAL 9000 option! Please post back if you have success!
Show messages: All  1  2-8
