Unfold Pipe Model and sheet metal
 1-3  4-23  24-35
11901.4
is there any tutorial for making it.. i dont understand..
11901.5 In reply to 11901.4
My Moi French Site
11901.6 In reply to 11901.5
thank u but this dont help me i dont know what tool u use. is it script or what?
11901.7
One thing I use sometimes is https://pepakura.tamasoft.co.jp/pepakura_designer/download/
Draw in Moi import there and get the templates. it is quick.
You also have https://www.bend-tech.com/software/
if you need to do allot of roll cages it could be worth it.
11901.8 In reply to 11901.6
It's just Flow function but alas that works not good with complete cylinder!
In my example that is not a complete cylinder so works fine!
Use : Copy Past in place the top external arc Cylinder (will be the Base curve)
Look at Detail (up page right for have the length of this arc (will be the target line - the same than the script Unwrap Curve )
Draw a line of this length : the Target line
Select the object Cylinder with the window
Call the Flow function
Click the arc Circle (pasted) as start curve
Click the target line drawn
Et voilĂ  you have your unfolded object! ;)
EDITED: 13 Jan by PILOU
11901.9 In reply to 11901.8
THIS WHAT I NEED I DRAW IT MANUALY BUT I THINK NOT CORRECT..
i need only lines for paper template..
Size: 213.9 KB, Downloaded: 43 times, Dimensions: 1026x710px
11901.10 In reply to 11901.9
Hi 4rw1n,
Please post the .3dm model file with those objects.
11901.11 In reply to 11901.9
Here is a quick "Curve to Curve Flow"
If you rotate the object, you can get the curve to unwrap the way you show. Depends on how you want the edges to cut...
11901.12 In reply to 11901.11
THis is the rotation i was talking about to get the edges you want for a cut
11901.13
Wish Moi3d will get unfold surface or 3d model unfold options in the future.
11901.14 In reply to 11901.11
@Burrman fell across your YouTube channel. Amazing. Are you possibly available for custom video tutorials? Cost? Thank you!
11901.15 In reply to 11901.14
Hi Nate,
Sorry, i don't do that… hope you find something.
11901.16 In reply to 11901.15
somethimes i cant separate line
Size: 70 KB, Downloaded: 31 times, Dimensions: 735x583px
11901.17 In reply to 11901.16
The line is a single entity folding over on itself with no segments. There is no "separation.
I am not sure how to arrange to Unfold that particular shape. For me it is starting to get into the non developable arena and want to go to software meant to do that.
Maybe Michael can direct unrolling that cylinder?
Here is a video where I use Pepakura to unfold it. But you are now "dicing up your model". So you will have to make a determination on tolerances and accuracy
11901.18 In reply to 11901.16
Hi 4rw1n,
It looks like using a closed curve for the base curve is problematic because a point that maps onto the seam point of the base curve is equally close to 2 locations on the unwrapped line.
I think you can solve this by splitting it in half and processing each half separately:
11901.19 In reply to 11901.18
And just to clarify on how you do the unwrap using curve flow, you have 3 pieces:
#1 is half of the top edge of the cylinder. This is the object that you will give as the object to deform, select it before running Flow.
#2 is half of the bottom circle of the cylinder. This is the base curve for the flow.
#3 is a line that has the same length as the half bottom circle, this is the target curve for flow.
Usually Flow is done with a straight line base curve onto a curved target but you can do it curved to straight as well.
This will be the result, it is floating above the line, you do the other halves in a second run of flow:
11901.20 In reply to 11901.18
Aha!!!
11901.21 In reply to 11901.19
Oh and for that line above, the #3 - you don't actually need to make it the line the exact same length as the arc as long as you don't enable the "Stretch" mode in the flow options.
When Stretch is off it will match "distance traveled along base curve" to the same distance traveled along the target curve, automatically extending if needed.
When Stretch is on it will match "percentage traveled along base curve" to the same percentage traveled along the target curve.
11901.22 In reply to 11901.20
thank u guys.. now i need unfold sheet metal ..is there sript..
Size: 179.7 KB, Downloaded: 43 times, Dimensions: 1000x749px
11901.23 In reply to 11901.22
Hi 4rw1n,
Sorry no none that I am aware of.
You might check out FreeCAD which has a sheet metal module, or Pepakura Designer.
Show messages:  1-3  4-23  24-35
