Rotate objects 90º relative to view
All  1-6  7-16
11898.7 In reply to 11898.5
Hi Marc, ok try the attached script.
Instructions for installing a plug-in script command here.
Set one of these for the command on each arrow key shortcut, note there should be a space after "Rotate90RelativeToView" :
Rotate90RelativeToView Left
Rotate90RelativeToView Right
Rotate90RelativeToView Up
Rotate90RelativeToView Down
EDIT: applied bug fix from Mik
EDITED: 15 Jan by MICHAEL GIBSON
11898.8 In reply to 11898.7
Works like a charm, you are a magician !
Thanks for taking the time to look at this.
Here's a project I'm working on, a Morris chair design with assorted table and leg rests in cherry wood .
The command will help in the laying out of individual parts.
Marc
11898.9
The spacebar script to switch view is fast also...especially on a laptop.
cannot live without it.
11898.10 In reply to 11898.9
Indeed !
Is it the script that toggles the active viewport to fullscreen, and goes back to split view if pressed again ?
Marc
11898.11
Yes..thats the one. ctrl+spacebar will flip left to right, front to back etc.
EDITED: 11 Jan by MATADEM
11898.12
Hi Matadem,
I didn't know about flipping the view 180º, quite interesting.
Thanks !
Marc
11898.13 In reply to 11898.12
Ctrl+space script:moi.ui.mainWindow.viewpanel.reverseView( moi.ui.getActiveViewport().name );
This is the way I have it setup.
11898.14 In reply to 11898.13
Thanks !
Marc
11898.15 In reply to 11898.7
Hello Michael,
I've noticed that if I set arrow key Up with command Rotate90RelativeToView Up, so the model turn Down and vice versa, if I set arrow key Down with command Rotate90RelativeToView Down, so the model turn Up,
therefore I changed the order of code from:
case 'left': view_dir = frame.yaxis; view_dir.scale( -1.0 ); break;
case 'right': view_dir = frame.yaxis; break;
case 'up': view_dir = frame.xaxis; break;
case 'down': view_dir = frame.xaxis; view_dir.scale( -1.0 ); break;
to
case 'up': view_dir = frame.xaxis; view_dir.scale( -1.0 ); break;
case 'down': view_dir = frame.xaxis; break;
now the model rotation correspond to arrow key dirrection.
Is that right?
Mik
11898.16 In reply to 11898.15
Hi Mik, yes you're correct, thanks for the bug fix. I have updated the script above.
Show messages: All  1-6  7-16
