Rotate objects 90º relative to view
All  1-3  4-16
11898.4 In reply to 11898.3
Hi Marc, so local horizontal relative to the 3D view would be like this:
Or do you want the rotations to only be in the world x, y, z axis directions which would be one of these 3 directions:
11898.5 In reply to 11898.4
World x,y,z axis in 3d view.
Marc
11898.6 In reply to 11898.4
Thinking about it, 3D view-based rotation as you described could also be interesting to quickly adjust object rotation.
But this would be for a different usage than for making plan details.
Adjusting profiles along a sweep object of organic shapes could be a usage example.
Maybe this manner could work without the rotation angle 90º constraint or have a modifier to snap to.
The command could trigger rotate, center, and mouse "up or down" or "left and right" could approximate the rotation angle.
Marc
11898.7 In reply to 11898.5
Hi Marc, ok try the attached script.
Instructions for installing a plug-in script command here.
Set one of these for the command on each arrow key shortcut, note there should be a space after "Rotate90RelativeToView" :
Rotate90RelativeToView Left
Rotate90RelativeToView Right
Rotate90RelativeToView Up
Rotate90RelativeToView Down
EDIT: applied bug fix from Mik
EDITED: 15 Jan by MICHAEL GIBSON
11898.8 In reply to 11898.7
Works like a charm, you are a magician !
Thanks for taking the time to look at this.
Here's a project I'm working on, a Morris chair design with assorted table and leg rests in cherry wood .
The command will help in the laying out of individual parts.
Marc
11898.9
The spacebar script to switch view is fast also...especially on a laptop.
cannot live without it.
11898.10 In reply to 11898.9
Indeed !
Is it the script that toggles the active viewport to fullscreen, and goes back to split view if pressed again ?
Marc
11898.11
Yes..thats the one. ctrl+spacebar will flip left to right, front to back etc.
EDITED: 11 Jan by MATADEM
11898.12
Hi Matadem,
I didn't know about flipping the view 180º, quite interesting.
Thanks !
Marc
11898.13 In reply to 11898.12
Ctrl+space script:moi.ui.mainWindow.viewpanel.reverseView( moi.ui.getActiveViewport().name );
This is the way I have it setup.
11898.14 In reply to 11898.13
Thanks !
Marc
11898.15 In reply to 11898.7
Hello Michael,
I've noticed that if I set arrow key Up with command Rotate90RelativeToView Up, so the model turn Down and vice versa, if I set arrow key Down with command Rotate90RelativeToView Down, so the model turn Up,
therefore I changed the order of code from:
case 'left': view_dir = frame.yaxis; view_dir.scale( -1.0 ); break;
case 'right': view_dir = frame.yaxis; break;
case 'up': view_dir = frame.xaxis; break;
case 'down': view_dir = frame.xaxis; view_dir.scale( -1.0 ); break;
to
case 'up': view_dir = frame.xaxis; view_dir.scale( -1.0 ); break;
case 'down': view_dir = frame.xaxis; break;
now the model rotation correspond to arrow key dirrection.
Is that right?
Mik
11898.16 In reply to 11898.15
Hi Mik, yes you're correct, thanks for the bug fix. I have updated the script above.
Show messages: All  1-3  4-16
