Rotate objects 90º relative to view
All  1-9  10-16
11898.10 In reply to 11898.9
Indeed !
Is it the script that toggles the active viewport to fullscreen, and goes back to split view if pressed again ?
Marc
11898.11
Yes..thats the one. ctrl+spacebar will flip left to right, front to back etc.
EDITED: 11 Jan by MATADEM
11898.12
Hi Matadem,
I didn't know about flipping the view 180ยบ, quite interesting.
Thanks !
Marc
11898.13 In reply to 11898.12
Ctrl+space script:moi.ui.mainWindow.viewpanel.reverseView( moi.ui.getActiveViewport().name );
This is the way I have it setup.
11898.14 In reply to 11898.13
Thanks !
Marc
11898.15 In reply to 11898.7
Hello Michael,
I've noticed that if I set arrow key Up with command Rotate90RelativeToView Up, so the model turn Down and vice versa, if I set arrow key Down with command Rotate90RelativeToView Down, so the model turn Up,
therefore I changed the order of code from:
case 'left': view_dir = frame.yaxis; view_dir.scale( -1.0 ); break;
case 'right': view_dir = frame.yaxis; break;
case 'up': view_dir = frame.xaxis; break;
case 'down': view_dir = frame.xaxis; view_dir.scale( -1.0 ); break;
to
case 'up': view_dir = frame.xaxis; view_dir.scale( -1.0 ); break;
case 'down': view_dir = frame.xaxis; break;
now the model rotation correspond to arrow key dirrection.
Is that right?
Mik
11898.16 In reply to 11898.15
Hi Mik, yes you're correct, thanks for the bug fix. I have updated the script above.
Show messages: All  1-9  10-16
