How do I avoid these lines when revolve?
All  1  2-4
11897.2 In reply to 11897.1
Hi Matadem, can you please post the curves you are using for the rail revolve?
11897.3
I think my problem was in the ellipse..after I rebuild no more lines...
but attached is aprox what I used the og was deleted.
Tnx!
11897.4 In reply to 11897.3
Hi Matadem, this version isn't making those lines.
Probably what happened in your deleted file is that the ellipse was made up of several segments. You'll get one section for each segment in the rail curve.
To get rid of that you could use rebuild or merge to make the multiple segments fused into a single segment.
Show messages: All  1  2-4
