pises and structures
 1-4  5-23
11891.5 In reply to 11891.2
hii
this what i need.. thank u alot.. tell me where can i download and install all plugins scripts like u
11891.6 In reply to 11891.5
Hi 4rw1n, there are some links on the resources page:
https://moi3d.com/resources
Look for "Burr's script archive", "Petr's MoI page", and "Max Smirnov's MoI scripts".
Instructions for installing a script here.
11891.7 In reply to 11891.6
how to add like this
Size: 180.1 KB, Downloaded: 46 times, Dimensions: 378x372px
11891.8 In reply to 11891.7
"""""""how to add like this"""""""""
That is Max Smirnoff custom UI
You can find it in links Michael posted
Mine is a bit customized. But only to add other things, the default one will give you the commands list
11891.9 In reply to 11891.8
i just install there alot options i dont like.. i want like ur simple but good.. of course if not problem to share
11891.10 In reply to 11891.9
Should be able to get what you want by going to appdata directory and looking for startup folder and find the list of CustomUI stuff in there...
Put a minus character at the beginning of any entry you want to not show up in that list, like this
-99 LogScroll.js
EDITED: 4 Jan by BURRMAN
Message 11891.11 deleted 4 Jan by BURRMAN
11891.12 In reply to 11891.10
Just a quick note on the appdata folder. By default the appdata folder (on Windows) is at %AppData%\Moi .
In the config Burr shows above he's made an appdata folder inside the install folder c:\Program Files\MoI 5.0 beta Sep-17-2025\appdata which is an optional way to set things up to make a "portable" version that has everything contained inside one folder.
11891.13 In reply to 11891.3
BurrMan is a very diplomatic:
Feel free to come back with more Q&A and help with using MoI and how to model with MoI and get things done in MoI.
I don't always have this quality:
I don't understand why you so often advertise other software when there are often solutions with MoI.
What's more, you're lucky enough to have a French forum just for you.
EDITED: 6 Jan by ZOOEN
11891.14 In reply to 11891.13
I don't believe that Burrman message was for me !
Look at the Number of its message adress! ;)
About the other free progs for go inside Moi I have always made that since quasi 20 years! :..
EDITED: 6 Jan by PILOU
11891.15
Hmm. No time to think about the implementation, but it seems like it should be relatively easy to built that assembly as a set of curves describing the centerline of each tube. Give each tube thickness a different color, then run a script that sweeps a circle of that size along each curve. Do a few boolean operations afterword and you should have clean joints — possibly with some caveats when you're dealing with multiple pipes joining in a single spot. Keep the original curves around and if the frame geometry changes you can regenerate the pipe version.
11891.16 In reply to 11891.14
4rw1n > Im drawing the chassis of a buggy. But I can't easily draw the chassis in MOI. I mean, I can draw it, but it's not easy and it's not correct; it's difficult to connect the points.
- Here he explains his problem, his difficulties.
4rw1n> Is there something similar in MOI 3D?
- Here he clearly expresses his request.
For me, he wants to create his buggy frame with MOI 3D.
BurrMan >,Ask for help using MoI, modeling with MoI, and completing your projects in MoI.
- But then again, maybe it was just MoI (me) who saw a little message in it.
I looked for a buggy frame design similar to 4rw1n's, but couldn't find anything satisfactory. So I'm going to use 4rw1n's image to create the buggy frame with MoI3D, just for fun.
EDITED: 7 Jan by ZOOEN
11891.17 In reply to 11891.16
“”””””” maybe it was just MoI (me)””””””
Lol….
Welcome to Pleiades!
11891.18 In reply to 11891.16
hey man.. if u want i can send u org file u can recreate itd.. and send us here...
i want make it full here how will look.. but i dont alot of time..
Size: 1 MB, Downloaded: 73 times, Dimensions: 1333x987px
Excellent!
My Moi French Site
11891.20 In reply to 11891.18
Yes, you can send it in a private message or directly on the website.
Best regards.
- Zooen
11891.21
thank u guys now look perfect
Size: 2.7 MB, Downloaded: 56 times, Dimensions: 2560x1946px
11891.22 In reply to 11891.21
Hi 4rw1n,
@ thank u guys now look perfect
Totally with MoI3D?
- Zooen
11891.23 In reply to 11891.22
yes its make over script in moi ..very easy and helpfull
Show messages:  1-4  5-23
