pises and structures
 1-10  11-23
Message 11891.11 deleted 4 Jan by BURRMAN
11891.12 In reply to 11891.10
Just a quick note on the appdata folder. By default the appdata folder (on Windows) is at %AppData%\Moi .
In the config Burr shows above he's made an appdata folder inside the install folder c:\Program Files\MoI 5.0 beta Sep-17-2025\appdata which is an optional way to set things up to make a "portable" version that has everything contained inside one folder.
11891.13 In reply to 11891.3
BurrMan is a very diplomatic:
Feel free to come back with more Q&A and help with using MoI and how to model with MoI and get things done in MoI.
I don't always have this quality:
I don't understand why you so often advertise other software when there are often solutions with MoI.
What's more, you're lucky enough to have a French forum just for you.
EDITED: 6 Jan by ZOOEN
11891.14 In reply to 11891.13
I don't believe that Burrman message was for me !
Look at the Number of its message adress! ;)
About the other free progs for go inside Moi I have always made that since quasi 20 years! :..
EDITED: 6 Jan by PILOU
11891.15
Hmm. No time to think about the implementation, but it seems like it should be relatively easy to built that assembly as a set of curves describing the centerline of each tube. Give each tube thickness a different color, then run a script that sweeps a circle of that size along each curve. Do a few boolean operations afterword and you should have clean joints — possibly with some caveats when you're dealing with multiple pipes joining in a single spot. Keep the original curves around and if the frame geometry changes you can regenerate the pipe version.
11891.16 In reply to 11891.14
4rw1n > Im drawing the chassis of a buggy. But I can't easily draw the chassis in MOI. I mean, I can draw it, but it's not easy and it's not correct; it's difficult to connect the points.
- Here he explains his problem, his difficulties.
4rw1n> Is there something similar in MOI 3D?
- Here he clearly expresses his request.
For me, he wants to create his buggy frame with MOI 3D.
BurrMan >,Ask for help using MoI, modeling with MoI, and completing your projects in MoI.
- But then again, maybe it was just MoI (me) who saw a little message in it.
I looked for a buggy frame design similar to 4rw1n's, but couldn't find anything satisfactory. So I'm going to use 4rw1n's image to create the buggy frame with MoI3D, just for fun.
EDITED: 7 Jan by ZOOEN
11891.17 In reply to 11891.16
“”””””” maybe it was just MoI (me)””””””
Lol….
Welcome to Pleiades!
11891.18 In reply to 11891.16
hey man.. if u want i can send u org file u can recreate itd.. and send us here...
i want make it full here how will look.. but i dont alot of time..
Size: 1 MB, Downloaded: 73 times, Dimensions: 1333x987px
Excellent!
My Moi French Site
11891.20 In reply to 11891.18
Yes, you can send it in a private message or directly on the website.
Best regards.
- Zooen
11891.21
thank u guys now look perfect
Size: 2.7 MB, Downloaded: 56 times, Dimensions: 2560x1946px
11891.22 In reply to 11891.21
Hi 4rw1n,
@ thank u guys now look perfect
Totally with MoI3D?
- Zooen
11891.23 In reply to 11891.22
yes its make over script in moi ..very easy and helpfull
Show messages:  1-10  11-23
