Splitting model in squares?
All  1-3  4-12
11882.4 In reply to 11882.1
If all you need is a visual check, then maybe the Grid would serve that purpose.
Martin.
11882.5 In reply to 11882.4
Its a big piece which will be divided by allot of pieces about length about 2 meters.
This is maybe useful!
Boolean Merge
then Explode Move
all Native functions!
Each piece is a solid!
EDITED: 30 Dec 2025 by PILOU
11882.7 In reply to 11882.1
Hi Matadem,
> and I want to split the model into squares
To split a model into square chunks, draw one square of your target size:
Select it and run Transform > Array > Grid. It will ask you for the number of copies to make, the default is to make 10 in x and 10 in y.
For the spacing pick the first point here:
And second point here:
You will now have a grid of squares, position your object within it and select your object:
Run Construct > Boolean > Intersect, then select the squares and you'll get split up pieces like this:
Hope this helps! - Michael
Message 11882.8 deleted 31 Dec 2025 by BURRMAN
11882.9
Tnx...how would I manage the ones that surpass the limits?
indicating by red arrow?.
Size: 127.7 KB, Downloaded: 34 times, Dimensions: 740x466px
Message 11882.10 deleted 31 Dec 2025 by BURRMAN
11882.11 In reply to 11882.9
You can use from the beginning 2 perpendicular Construct / Curve / Iso
Then Draw some points on them for have some measures for draw the other Iso curves!
You will obtain only "squares" curvated on the sphere! ;)
If you don't want poles use a sphere from a cube
_subdBeta9 by Max Smirnov
EDITED: 31 Dec 2025 by PILOU
11882.12 In reply to 11882.9
Hi Matadem,
Do you mean you want to limit the elevation as well?
For that you would need to split the model with cubes, not squares.
You can do that with the same pattern above, but instead of drawing a square draw a cube:
When you run Transform > Array > Grid, fill in a number of copies in the Z direction, not just X and Y:
When picking the cell size for the array spacing there will be an additional step for the z spacing.
For the cell size pick points like this:
That will generate a cube made up of cubes like this:
It would probably be a good idea to select the cubes and assign them a name (click on "Unnamed" in the upper right of the main window) so you can select and hide them more easily using the Scene Browser.
Then position your object inside the cube, select just the object and run Construct > Boolean > Intersection, then select the small cubes and you'll get a result like this:
EDITED: 31 Dec 2025 by MICHAEL GIBSON
Show messages: All  1-3  4-12
