Multipipe in Moi?
All  1  2-4
11878.2 In reply to 11878.1
Hi Matadem,
> Is there a way to do multipipe in Moi3d?
> or close?
I don't know of any already existing script to generate a multiple pipe hub like that.
To construct one it would probably be good to form it as a sub-d control cage and convert that into smooth surfaces using SubD > Create > From file.
11878.3 In reply to 11878.2
You mean in a poly program or something else and then create subd from file?
11878.4 In reply to 11878.3
Hi Matadem,
I meant in a script.
Maybe I'm not understanding your request though, the page you referenced was for a Grasshopper module, it's kind of like a building block that can be used by a script.
If you just want to create some geometry like that then yes constructing it as a sub-d control cage using a poly modeling program would probably be the most feasible. Sub-d tends to work well for branching structures like that.
Show messages: All  1  2-4
